Mike96
Lifting the limitations of Dormer Shed library
I've got a problem with the native Dormer Shed in Archicad 25 and 28. I think its maximum Shed Roof Pitch value (screenshot) is hardcoded at 35 degrees. This is highly impractical and illogical limitation, and it should be increased to something like 89 deg. Sadly, I can't edit GDL myself, so I'm hoping someone would be able and so kind to try fixing it.
I placed it as skylight but the issue is the same if placed as an object.
PS
Sorry for Polish UI but I don't think this will be a problem.
Attached test model. Should I upload PLA or is PLN enough? Anyone can also start from scratch, it's a super simple example.
Operating system used: Windows 10
ArchiCAD 25
Windows 10
10 Replies 10
Mike96
Jaime-airc_digital
You are the best! Thank you so much, your fix is gonna save me some real headache (hopefully, for other users too). And sorry for calling you personally. I hope it didn't take you too much time!
ArchiCAD 25
Windows 10
