You can rotate it in 3D and section/elevation using the middle hotspot. You can set if it is at top, middle or bottom in the object settings.
Only downside is, you can not rotate it this way, if you rotated the profile along its own axis.
www.leloup.nlArchiCAD 9-29NED FULL
Adobe Design Premium CS5
