‎2013-10-30 10:00 PM
‎2015-07-24 01:30 AM
stefan wrote:Navisworks does have Export Add-Ons for AC17 and AC18 as well (they are free). They were released this spring. You can download the install package from here:
Navisworks is also a proprietary Autodesk application, only running on Windows. The ArchiCAD connection it had was halted to an older ArchiCAD release (r14-15-16) and never updated. It works with IFC.
I totally agree on the problem of requirements that stipulate particular software that is closed, non-cross-platform and from a particular software vendor.
That is not a software issue, but more a lawyers issue. Good luck with that.
‎2015-07-24 02:37 PM
‎2015-07-27 12:12 AM
‎2015-07-27 12:14 AM
another Moderator
‎2015-07-27 12:47 AM
Miki wrote:That is correct, the design team very closely controls and co-ordinates all data, The tenderers ie builders , contractors, sub contractors are given dwg and limited BIM on a need to know basis.
..... It's all Revit now.
‎2015-07-27 03:30 AM
‎2015-07-28 04:14 AM
‎2015-07-30 12:53 PM
laszlonagy wrote:Hi Laszlo,
This is not something that should be taken as a promise or fact, but I am hearing news that GS may be working on a Rhino-Grashopper-ARCHICAD bidirectional connection. We already have Rhino-ARCHICAD one-directional connection, that's is a done deal since this spring. If this is true this is something that may be coming in the future.
Which makes me think about the following:
On other fronts, one can read in the news that Rhino for Mac is coming, and sometime in the (hopefully not too distant) future Grasshopper for Rhino will also be released. So if all these things happen, then ARCHICAD will hopefully have a bidirectional Rhino-Grasshopper connection on both the Windows and Mac platforms in the foreseeable future.
To me this sounds like a pretty good thing because the guys developing Rhino and Grasshopper can focus on those applications, while Graphisoft can focus on ARCHICAD. Actually, this is not a bad solution, in my opinion. At this year's AIA one of the big announcements of Autodesk was the making of Dynamo a stand-alone product independent of Revit. Previously it was part of Revit. So Dynamo (a Grasshopper-like visual algorithmic modeling environment) will now be able to connect to any other application as well, and will not be tied to Revit. Which makes it the same order of solution as a Rhino-Grasshopper connection to ARCHICAD.
We will see...
‎2015-08-02 07:38 PM
‎2015-08-05 11:53 PM
