2026-03-12 06:32 PM
I’m having an issue when entering distances in Archicad. Previously I could move an element with Command + D and simply type the distance (for example 20' or 5"). Now Archicad automatically inserts a feet symbol ' immediately after the first digit, before I finish typing.
For example:
If I try to type 20, it automatically becomes 2'0.
If I want 10, it becomes 1'0.
Because of this I cannot type multi-digit values normally. I have to delete the ' symbol or use the Reference Distance (R) every time, which I did not have to do before.
Nothing in my Working Units (Feet & Inches, fractional) has changed, and I already checked Tracker and Coordinate Input settings, but the behavior persists.
Has anyone encountered this before or knows what setting could cause Archicad to automatically insert the feet symbol after the first digit during numeric input?
Additional info:
I recorded a short video showing the issue. In the first attempt at drawing the line, I press R for reference distance and I’m able to enter the 20' distance I want without any problem.
In the second attempt, I try to simply type 20' directly without pressing R or any other key. You can see that after I type the 2, Archicad automatically inserts the feet symbol (') before I finish typing the number. I then have to delete that symbol in order to type the 0 and complete the distance.
In the last attempt, you can see what usually happens when I’m working quickly. I’m typing distances fast and don’t notice that the ' symbol was inserted automatically, so the value becomes incorrect and I have to stop and go back to fix it.
Previously I was able to work quickly and type distances directly without Archicad automatically inserting the feet symbol after the first digit. Now it happens every time unless I use R for reference distance, which slows down the workflow.
2026-05-20 09:20 AM
macOS 26.5 with Archicad-28.4.0-Update (7006) NZE - ISSUE FIXED
2026-05-20 05:45 PM
Distance input FIXED.
Angle input STILL AN ISSUE.
a month ago
Archicad 29.2.0 Update Preview has just been released:
a month ago
Unfortunately the Release Notes still seem to relate to Archicad 29.1.0 so we can't see what's been fixed.
a month ago
Release notes are here:
https://www.graphisoft.com/en-us/downloads/updates/archicad-29-2-0/?platform=windows&localization=IN...
and they show that the fix is included.
4 weeks ago - last edited 4 weeks ago
Hi I just switched to 29 and now am having this issue, thanks for the information.
4 weeks ago
Press tab before inputting the number or ‘R’. The next update for Archicad 29 fixes it.
4 weeks ago
Archicad preview update 29.2.0 solves this issue. I have installed it and using it without any further problems.
I have the same problem after macOS upgrade, and it is very annoying... slows down work in Archicad a lot, I hope garphisoft fix this soon for POL version.
3 weeks ago
This is crazy!! We have a bunch of projects in 27 and are planning on moving up to 29 or 30 (whenever is comes out), after we get through this HUGE production push. Am I to understand that I am S.O.L. because we are on 27?
