2006-01-12 04:45 AM
2006-01-12 05:46 AM
bruceprice wrote:hello! YES
maybe my previous firm was a little backwards
2006-01-12 06:55 AM
2006-01-12 01:20 PM
2006-01-12 02:09 PM
2006-01-12 03:16 PM
2006-01-13 04:23 AM
2006-01-13 05:30 AM
2006-01-13 08:47 AM
Ben wrote:This is putting it mildly ...bruceprice wrote:hello! YES
2006-01-13 09:45 AM
bruceprice wrote:I strongly suggest you to contact some local reseller or ArchiCAD-based firm, since you ask about a very typical workflow, which seems not that obvious at first sight.
Thanks everyone for responding. So it sounds like most of you are getting the most out of Archicad.
After I get my new copy of Archicad, I'll be using it primarily for wood frame residential construction. I'm guessing that a few of you probably do this sort of work also. If any of you have a moment, I'd REALLY appreciate if you could answer this series of questions in order to help me understand how the process of pulling drawings from a 3D model works:
If you do a section cut, can you automatically generate wall plates (and other standard wood frame structural details) by specifying 'wood frame' with the wall tool? Or do you have to add these manually every time you draw a wall? And do you do this by 3D modeling the wall plates? Or by 2D drafting them on to the section cut? And if you were to 2D draft lines onto the section cut, can the lines easily be linked to a 3D object so that if the 3D object were moved, the associated lines would automatically move with it? Can you automatically generate labels (i.e. you draw a (customized) wall with the wall tool and then open up the section and it already has cedar shingles, 1/2" plywood, & 2x6 @16" o.c. labeled?)
Finally, regarding lineweights, can the same object have 2 different line weights depending on the context of it's edge? For example. can a cornerboard be automatically programed to have a heavy line at the outer edge of a building and a much lighter line on it's inner edge, adjacent to the clapboard siding?
thanks so much!
