cadsph
CONC. Column No Outline?
I copied a series of Concrete columns,
for some reason, all the copied columns have no Outline in Section
I've looked at the pen & fill properties, but I can't see a difference btw them.
The columns are all aligned across section.
Please see attached.
1 Solution
There is nothing attached.
Make sure you do not have 2 columns occupying exactly the same space.
These will possibly cancel (trim) each other in 3D (hence section) which could be why you see no outline.
Go to post
2 Replies 2
cadsph
Yes. Your right thanks,
I had someone else look @ my model and they found the same thing!
