2023-10-13 04:32 PM
I am a begginer in Archicad so this might be basic but can´t figure it out. I create 3 different door sbase on an exisiting one by default in Archicad library. They are place in embeded library. I have placed some of this doors in the project I am working on, but I would like to be able to change some of this doors to other ones I have created. For example, I have one with 88 cm opening that I would like to change to another one of 76cm opening that I had already created. I read about the Syringe command, but I found that way of doing it kind of complicated. I would like to simply change from a door element to another I had already in the library, so in case I need to change multiple doors I can do it all at once. If I do it with Syringe it will take forever. Hope my problem is clear
Solved! Go to Solution.
2023-10-13 09:57 PM
try saving the one you want applied as a favorite. Then select the doors that need to change and apply the favorite to them by their element settings (little star icon in the upper left corner of the door settings)
2023-10-13 09:57 PM
2023-10-13 09:58 PM
also, you can quickly select groups of doors by drawing a marquee around the area containing just those doors, select the door tool from the tool box, then com+A.
this avoids the tedious task of shift clicking each door (almost as bad as injecting each door one at a time)
