2026-02-06
04:09 PM
2026-02-08
10:32 PM
Hi everyone,
I’m working in Archicad 28 and facing an issue with composite wall finishes at door openings.
Problem:
In a composite wall, I want the plaster finish to continue behind the door frame, but currently the plaster stops at the wall face and does not wrap behind the frame.
I am using:
Composite wall with plaster as the outer skin
Hinged Door (standard Archicad door)
Closure Type: Finish Closure
Wall Closure settings enabled in the Door Tool
2026-02-06 04:42 PM
The model looks correct. Maybe you can share a picture of what you want?
2026-02-07 06:38 AM
please have a look at how the plaster behaves with respect to the door frame, this is what i want
2026-02-07 11:02 PM
Uhh.... I don't think that any of the GS doors allow this; I've tried but didn't manage to accomplish this.
But on the other hand to have the plaster done like this is also highly unusually.
2026-08-28 09:34 AM
That type of drywall detail is used for bifold doors on closets where only a half jamb and trim is installed on the room side of the wall. The bifold door then fits behind the jamb eliminating the visible side gaps. It also saves 1/2 the cost of the door trim.
2026-08-28
11:02 AM
2026-08-29
05:55 PM
Could you use the Custom Closure? Do not think there is a way to merge the internal and external skins though...
The Plaster Reveal can do the same.
Ling.
