License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
Doors with sliced off-beveled tops? Dormer condition doors?
rob2218
see attached image.
query: need to make a custom (or if there is some in the library of doors) beveled top type doors for "dormer" conditions we have up north in the U.S.A.
How to?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
16 REPLIES 16
Erich
Rob,
I think you are stuck doing a custom door for this condition. Build it with slabs, walls, etc. Make a slab with an ID of wallhole to get the correct cutout.
Look at the manual for specifics.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
rob2218
I'm familiar with making a custom door panel with slabs but how or where do I make the "ID with wall cut out" variable read properly? I saw a tip somewhere a while back which had a real ornate window design circular I think it was and it was placed in a wall and the wall around the circular window fitted perfectly around the window frame. I think that's the I.D. comment you made but not quite sure how to set that.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Hello Rob,
After you have built your window in the plan, make one more slab
that is the exact shape of the outside of your window frame and is
positioned exactly in the same place as the frame. Give this slab the ID
"Wallhole" and save the assembly as a window object. You don't have
to edit the script because there will be a wallhole command in the script.
The ID is set in the info pallet box in the text field labeled "ID" which is
usually a number that you change to read "Wallhole" (without the quotes)
Peter Devlin
rob2218
thanks Peter.
I'll give it a shot tomorrow at work sir.
much, much appreciated.
cheers!
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
ok..the custom door was done with a simple "slab" then saved as a "custom component" but I'm not sure what the process is for having the door opening follow the door shape? it's that "I.D." additional slab I have to have but....where/how/when/at what point do I need to add that "I.D." variable in the saving process?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Hello Rob,
Custom Components are not relevant in this context.
Please build a complete door including frame, panel,
interior trim and exterior trim. Please see this thread.
http://archicad-talk.graphisoft.com/viewtopic.php?p=162048&highlight=wallhole#162048
Peter Devlin
rob2218
I must be as dense as a bag of rocks...
I did all that you suggested.
Create a door panel using a slab.
created a frame using beams (simply profile 2x4 frame).
created another slab for use with the wall I.D. hole.
when I selected all 3 parts, and went thru the steps...it captured the objects yet...the only that is show in 3d and in plan is the wall opening.
Neither the door nor the frames show up......like I said....there's just some minut step I'm missing I'm sure.
I can believe a simple beveled top door is taking this long.
My boss is gonna hang me by a tree for burning so much project time.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Hello Rob,
Are you building your door centered on
the project origin and on the first story ?
If you build on any other story the door
elements will be displaced and appear
far away from the wall they are supposed to be in.
Peter Devlin
rob2218
well..that was something that was not mentioned.
Should I be building the door "centered" on the project "X" origin 'AND' also on the first floor???
if that is the case..I'll try that now and see what results it gives me.
i>u
Edgewater, FL!
SOFTWARE VERSION:
