2015-09-25
05:43 PM
2023-05-25
05:39 PM
Rubia Torres
2015-09-25 06:07 PM
2015-09-25 08:44 PM
Dontknow wrote:I thought about that but that does not work as it does not add the necessary thickness for the stucco to get the same even plane.
Overide surface in the 'Slab Selection Settings'.
2015-09-25 08:52 PM
2015-09-25 10:44 PM
Stephen wrote:Could you elaborate a little further how I do that?
Add a small piece of wall the proper width and height.
2015-09-26 02:20 PM
2015-09-26 04:06 PM
another Moderator
2015-09-26 06:47 PM
ejrolon wrote:What's PBC?
not affected by PBC.
2015-09-26 06:53 PM
another Moderator
2015-09-26 08:22 PM
ejrolon wrote:To clarify, some elements are automatic in their PBC collision like Wall and Slab and Beams for example, some require connect (in the context menu) for example Wall or Slab with Morph.
... Basic reason is that Morph are not affected by PBC.
