Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Extend stucco over floor slab / Cover floor slab w stucco
How do I best resolve the following issue. I have an exposed floor slab edge that I need to cover w stucco. See attached pic...
What is the best approach to do this?
9 REPLIES 9
Dontknow
Overide surface in the 'Slab Selection Settings'.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
I thought about that but that does not work as it does not add the necessary thickness for the stucco to get the same even plane.
Stephen Dolbee
Add a small piece of wall the proper width and height.
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Could you elaborate a little further how I do that?
Stephen Dolbee
If your stucco is 1" thick, make the wall 1" thick and match the height that you need. Of course, put it on a layer that will not be visible in your floor plan.
Eduardo Rolon
For this type of condition I sometimes use a Morph instead of a wall. Basic reason is that Morph are not affected by PBC.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Dontknow
What's PBC?
I don't get it.
When I give a wall and a slab the same surface it looks the same.
ArchiCAD 25.
Eduardo Rolon
PBC= Priority Bases Connections
AC27 US/INT -> AC08
another Moderator
James B
ejrolon wrote:
... Basic reason is that Morph are not affected by PBC.
To clarify, some elements are automatic in their PBC collision like Wall and Slab and Beams for example, some require connect (in the context menu) for example Wall or Slab with Morph.
I know you know, but just for reference to others. I think a thin Composite Wall just with the finish or extend the above Wall down to the base of the Slab. This would clear up best in Section between the above Wall finish and the thin Wall in front of the Slab. Either way, regardless of the solution or element type if the two finishes are flush and are the same surface, then they will clean up in elevation (no line between the two surfaces).
James Badcock
Graphisoft Senior Product Manager
