2022-04-21
08:50 AM
2023-06-07
04:06 AM
Gordana Radonic
Hi!
Any suggestions on how to make grass stones as in the picture in Archicad?
It has to be in 3D and grass is a different material because it will be changed in the grass than in rendering software.
My idea is to make them from slabs and copy past all along 😄 am wondering if there is any other way?
Thank you!
2022-04-21 11:22 AM - edited 2022-04-21 11:25 AM
200 x 200 panels in concrete
80 wide Built-in Butt-glazed Frames with no panel overlap in grass
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
2022-04-25 11:05 AM
Hi! interesting solution, that would also work thank you!
In the best-case scenario, I would have some kind of texture (3d texture), which I could apply on paths. There are many paths with this kind of pavement, and modeling/adjusting for each takes some time ...
But workaround with curtain wall or saved objects with multiplied stones works also.
