4 weeks ago
Hi everyone,
I'm trying to extrude a helix by 5 cm in Archicad, but I'm running into an issue. The extrusion creates an uneven surface, and I haven’t been able to find a solution to make it smooth or uniform.
Is there a tool or technique in Archicad that can help me extrude the helix while keeping the surface even? Any suggestions would be greatly appreciated.
4 weeks ago
- last edited
4 weeks ago
Hi Edo
Try the curved ramp object in the library... That should do the trick.
Olivier
4 weeks ago
Draw a beam in the plane.
Wider than high rectangular section.
Transform into morph.
Move up and down the extremities to get your favourite geometry.
