Heftor
How to Make an Opening in a Composite Wall Without Removing the Skins
I’ve meticulously set up my composite wall structure, but when I place an opening, it cuts through every layer, including the crucial outside finish (brick, siding, stucco, etc.). This creates an incorrect representation in both 2D and 3D.
is there a way to preserve the outside layer (of the stucco) inside of the opening, like on the picture below:
Regards,
Hector
3 Replies 3
Gabor Szelei
I don't think there is a simple solution. Model it from a wall, a slab, a beam or a mesh.
Model it as it would be built in reality...
This solution works, but it's not very elegant 😉
Gábor
Versions 6.5 to 28, AMD Ryzen 9 3900x, 32GB ram, GeForce RTX 2070 super, Windows 10
CosminF
A workaround of sorts would be to make your opening from a simple window opening (from the window tool). That way, you can define a custom reveal that you might adjust to fit your needs. It doesn't neatly combine two surfaces, though, even if they are the same.
on the left is a regular opening, on the right is the window opening with reveal. The surface follows the edges as well:
hope this may help.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Guru
If you are going to use a Window, why not use a Rectangular Window Opening or similar and use the Closure settings?
Ling.
ps. When did they change the reveal to drawing the outside skin instead of just stretching the wall inward?
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
