Heftor
How to Make an Opening in a Composite Wall Without Removing the Skins
I’ve meticulously set up my composite wall structure, but when I place an opening, it cuts through every layer, including the crucial outside finish (brick, siding, stucco, etc.). This creates an incorrect representation in both 2D and 3D.
is there a way to preserve the outside layer (of the stucco) inside of the opening, like on the picture below:
Regards,
Hector
3 Replies 3
Gabor Szelei
I don't think there is a simple solution. Model it from a wall, a slab, a beam or a mesh.
Model it as it would be built in reality...
This solution works, but it's not very elegant 😉
Gábor
Versions 6.5 to 28, AMD Ryzen 9 3900x, 32GB ram, GeForce RTX 2070 super, Windows 10
CosminF
A workaround of sorts would be to make your opening from a simple window opening (from the window tool). That way, you can define a custom reveal that you might adjust to fit your needs. It doesn't neatly combine two surfaces, though, even if they are the same.
on the left is a regular opening, on the right is the window opening with reveal. The surface follows the edges as well:
hope this may help.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Guru
If you are going to use a Window, why not use a Rectangular Window Opening or similar and use the Closure settings?
Ling.
ps. When did they change the reveal to drawing the outside skin instead of just stretching the wall inward?
