Measuring problems in Teamwork
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2005-09-01
12:13 AM
‎2023-05-26
03:13 PM
Rubia Torres
However, I'm in a teamwork file and someone else is working on the plans and I'm on the elevations. How do I measure the size and location of a window if I can't use the line tool to measure with (i.e. I'm locked out of the plan space)? A measure tool would really be useful right about now.
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-09-01 12:26 AM
Simply hold shift + alt down and hover your cursor over the 'measure from' node. When your user origin relocates there, let go of shift + alt (but be sure to let go of shift first). Then simply hover your cursor over the 'measure to' node and read the distances in the co-ordinate box. You can use the x,y,r,a keys to copy and paste those measurements if you need to.
To return your user origin back to the project origin, simply double click your user origin button in the co-ordinate box.
Basic stuff - but a lot of people miss it.
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-09-01 12:48 AM
However, I would respectfully and meekly disagree that it's basic stuff. I missed it precisely because it's cryptic, not basic. In my opinion a measure tool would be basic stuff.
BTW - I use the line tool to measure because that's what I was trained to do by my local ArchiCAD distributors / trainers.
Mindmeister Mindmap
-- since v8.1 --
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-09-01 12:50 AM
Cheers
Mindmeister Mindmap
-- since v8.1 --
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-09-01 12:56 AM
I'll be down there soon - where are you?
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-09-01 01:04 AM
Mindmeister Mindmap
-- since v8.1 --
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-09-01 05:00 AM
Bruce wrote:I think what Link means is that it SHOULD be covered in basic training, even though it may not be. A lot of trainers focus on all the "gee-whiz" features almost like the sales reps do, instead of actually how to use the program in a professional setting.
Thank you Link.![]()
That's why I like guys like Link, Karl, Matthew, and some others who not only teach, but can dust most "power users" in actual usage.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-09-01 06:19 AM
Simply hold shift + alt down and hover your cursor over the 'measure from' node. When your user origin relocates there, let go of shift + alt (but be sure to let go of shift first). Then simply hover your cursor over the 'measure to' node and read the distances in the co-ordinate box. You can use the x,y,r,a keys to copy and paste those measurements if you need towell, the problem is when you want to measure a perpendicular distance to the target for example (the most common measurement that we do on plans, I recon) and you're scr..ed mate. so may be we should have some tool for measurements (??)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-09-01 08:12 AM
Rob wrote:Any linear tool will do ... wall, beam, polyline.
Or, click on the line that represents the window width and open Object info. It will tell you the lenght.
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-09-01 08:56 PM
Hypothetical: Two walls meet at an acute angle in a workspace that isn't reserved for you. How do you measure perpendicular to the wall that doesn't run in either the x or y axes? Opening the window tool to read the distance doesn't work because you're after the positioning, not the size.
Mindmeister Mindmap
-- since v8.1 --
