ā2005-09-01
12:13 AM
ā2023-05-26
03:13 PM
Rubia Torres
ā2005-09-01 12:26 AM
ā2005-09-01 12:48 AM
ā2005-09-01 12:50 AM
ā2005-09-01 12:56 AM
ā2005-09-01 01:04 AM
ā2005-09-01 05:00 AM
Bruce wrote:I think what Link means is that it SHOULD be covered in basic training, even though it may not be. A lot of trainers focus on all the "gee-whiz" features almost like the sales reps do, instead of actually how to use the program in a professional setting.
Thank you Link.![]()
However, I would respectfully and meekly disagree that it's basic stuff. I missed it precisely because it's cryptic, not basic. In my opinion a measure tool would be basic stuff.
BTW - I use the line tool to measure because that's what I was trained to do by my local ArchiCAD distributors / trainers.
ā2005-09-01 06:19 AM
Simply hold shift + alt down and hover your cursor over the 'measure from' node. When your user origin relocates there, let go of shift + alt (but be sure to let go of shift first). Then simply hover your cursor over the 'measure to' node and read the distances in the co-ordinate box. You can use the x,y,r,a keys to copy and paste those measurements if you need towell, the problem is when you want to measure a perpendicular distance to the target for example (the most common measurement that we do on plans, I recon) and you're scr..ed mate. so may be we should have some tool for measurements (??)
ā2005-09-01 08:12 AM
Rob wrote:Any linear tool will do ... wall, beam, polyline.
ā2005-09-01 08:56 PM
