Read more
Missing fills / 2d hatches
I can´t find the brick wall fill for illustrating the wall in my elevations. The only fill I have available in the wall default settings are the composite structure.
When I go into the element attributes: materials everyone comes up with "missing" in vectorial hatch. The the only thing I can choose is the fill type.
Why can´t I find more fills? I need the brick wall to show in my elevation. + edit it... Can´t find any similar posts or tips about downloading vectorial hatches or fill either. Please help me!
4 REPLIES 4
1. I have a lot of fills available
2. Check the Elevation Settings
Djordje
Ace
If you have a template file, merge it into your current project.
If you know how, use the Attribute manager to bring all the default fills in.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
David Maudlin
If you don't, open a New & Reset All new file (Command+Option N), which will open a new blank file with the default fills.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Djordje
Ace
... then save the blank file and merge it into your project
Djordje
HP Omen
