New Tutorial Video - Shortcuts for Construction Geometry
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2017-01-11
01:52 AM
2023-05-24
08:34 AM
Rubia Torres
ARCHICAD QuickTips Tutorial #3 - Geometry Construction Shortcuts
I think these two keyboard shortcuts may be hidden gems that deserve a little more limelight!
P.S. During the video, I mentioned that I didn't know a keyboard shortcut for switching a wall from one side of the reference line to the other side; I've been informed by a couple of savvy users that the "P" key will do that. I love learning new shortcuts!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-01-11 02:06 AM
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-01-11 02:21 AM
The tutorial focuses on the use of two keyboard shortcuts for changing settings on the fly:
-- "G" for geometry methods
-- "C" for construction methods
My note in the post was to add:
-- "P" for Flipping the wall orientation
Note that flipping is different than changing the construction reference. Ever since ArchiCAD 17 introduced the more flexible system of reference lines and planes, a wall reference line can be set as exterior side, interior side, center, exterior core or interior core. "C" will flip between all of these options.
"P" will flip from left to right in relation to the direction of the reference line. So you might be drawing the exterior face of the wall, but find that the wall is "facing" the wrong way. If you changed the construction method, you might switch to interior face and the body of the wall will be on the other side of the line, but that isn't necessarily what you want. By using the "P" key, you can keep the reference line on the exterior face, but make the body of the wall go on the other side of the line.
Eric
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-01-11 08:18 AM
Eric wrote:Great tuts you're producing! I'll have to start using G
Eduardo -
Eric
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-01-11 06:43 PM
You are right: when a wall is simple or a symmetrical composite or profile (which is common for interior walls with drywall or other cladding on both sides) then you're right, the terms inside and outside are not appropriate.
However for exterior walls, there are "exterior" and "interior" sides, and the way the composite is defined (top to bottom in the skin order) is relevant and appropriate.
Eric
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-01-11 07:41 PM
I've been looking at reference lines more closely, and have come to the conclusion that the Reference Guide is very confusing: "The reference line position determines the Wall’s “outside” and “inside” surfaces. (The reference line is on the outside of the Wall.) Separate surface materials can be applied to the Wall’s “outside” and “inside” surfaces, using the controls in the Model Panel of Wall Settings."
I'm not sure how it's possible to know which is inside and outside when the reference line is set to the center of the wall, so I like Mats's definition better.
AC26 (since AC6.0), Win10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-01-12 05:37 AM
I found reference lines to be great for wall connections and alignment between stories particularly when using the wizard. A great improvement over previous versions. easy to use and great to allow for framing and cladding.
The problem I have is in trying to align a complex profile wall with any other type wall. The single origin which can only be moved via offset which just messes with my calculator. Definitely need a better method. It would be better to allow more than one reference point (origin) with complex profiles with the ability to cycle through them, so as to allow for more versatile and precise alignments.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-01-12 08:58 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-01-17 06:37 PM
Mats_Knutsson wrote:I would like to have a reference core, and a reference line.
Half our staff draw the walls clock wise and the other half...yes...always fun with the inside out discussions...
Inside or Outside are only graphic words. They can lose their meaning for an interior wall and other places.
Why not just use the terms side A or side B ?
Other skins would be relative to the Reference Core, not the reference line. That would free up the reference line to be use for just placement/alignment and clean up purposes. Scheduling could also be associated with side A or side B of the Reference Core rather than the reference line. ?
