New composite not showing up in available composite list
I made a new composite, consisting of a brick wall of 80 cms. When creating it I made sure to mark that it can be used as a composite for walls.
However, when drawing the wall, I can not choose my newly created composite from the list.
Any idea what I'm doing wrong?
Best regards,
Vincent
7 Replies 7
Erwin Edel
You need to change the structure from Basic (which uses building materials) to Composite.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Ooh I see! Thank you very much for the fast reply! Is this a new feature in AC19? I'd done the same procedure as I did now already a lot of times in AC18 but never stumbled upon this before!
Erwin Edel
Building materials were introduced in ArchiCAD17, so it shouldn't be new.
www.leloup.nl
The question is why do you define a Composite Structure that has only one skin?
For structures with one skin you have the "Basic" Wall/Slab/Roof/Shell Structure type you can use.
Unless you want to fix the width of your wall.
Then even for a single skin I would use a composite so I don't have to manually set the wall width.
So you would create a Composite for each different thickness of the same Wall material? Like, 100 mm brick, 150 mm brick, 250 mm brick, etc.? Interesting idea.
Exactly.
