2016-01-21
03:53 PM
2023-05-24
08:44 AM
Rubia Torres
2016-01-21 04:22 PM
2016-01-21 04:29 PM
Erwin wrote:Ooh I see! Thank you very much for the fast reply! Is this a new feature in AC19? I'd done the same procedure as I did now already a lot of times in AC18 but never stumbled upon this before!
You need to change the structure from Basic (which uses building materials) to Composite.
2016-01-22 08:35 AM
2016-01-22 07:37 PM
2016-01-25 01:58 AM
laszlonagy wrote:Unless you want to fix the width of your wall.
The question is why do you define a Composite Structure that has only one skin?
For structures with one skin you have the "Basic" Wall/Slab/Roof/Shell Structure type you can use.
2016-01-25 02:02 AM
Barry wrote:So you would create a Composite for each different thickness of the same Wall material? Like, 100 mm brick, 150 mm brick, 250 mm brick, etc.? Interesting idea.laszlonagy wrote:Unless you want to fix the width of your wall.
Then even for a single skin I would use a composite so I don't have to manually set the wall width.
2016-01-25 02:10 AM
laszlonagy wrote:Exactly.
