4 weeks ago
Hello
I have a joist object (written a long time ago (v19) and when in the same model space as a composite floor, the object fill doesnt show. However, the strange thing is that the object fill shows correctly in other sections. i have checked, layer order, done a solid operation, changed intersection priority but am stumped. Can anyone help please?
Solved! Go to Solution.
3 weeks ago
Thanks for the PLA.
I know what is causing the problem (I think), but not why.
When I copy one slab and joists, I see the same problem.
The void in the slab seems to be causing the issue, I don't know why.
Cut a section looking away from the void and it is good.
Delete the void and it is good.
Obviously these are not solutions though.
But I found if you turn on transparency in the section settings, it look better.
But of course transparent materials will be see through, which may or may not be an issue.
3 weeks ago
You mentioned 'layer order'.
Do you mean 'Display Order' (i.e. bring forward / send back)?
If not, try that.
3 weeks ago
Hi Barry
Thanks for your reply. I think I meant the display order in the layer settings. I have tried 'bringing to front' but does not seem to work. Does it have anything to do with the object? Which was created in v15/19?
3 weeks ago
I am assuming the object is a 3D joist an not just a 2D overlay?
What version of Archicad are you using and is it the latest build?
I have tried testing in 28 with a 3D joist object and an 2D overlay object, but I can not replicate the issue.
It could be the object but it is quite hard to say without your actual object and floor composite.
3 weeks ago
Do you have any GO's active?
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
3 weeks ago
3 weeks ago
Thanks for the PLA.
3 weeks ago - last edited 3 weeks ago
Hi Barry,
It is bizarre that the hole in the slab is causing the issue but I can live with the transparency for this little project.
I appreciate you looking into this for me!
Dwayne.
3 weeks ago
I feel like Barry posted the same answer to a question, assume it is the same topic, a few years ago...
