2016-08-24 12:32 AM - last edited on 2023-05-23 02:20 PM by Rubia Torres
2016-08-24 04:09 AM
2016-08-24 05:59 AM
2016-09-05 08:11 PM
nojaano wrote:The way you model anything in ArchiCAD depends very much on what you need it for.
Can someone explain how to cut out the roof this hole? (the second roof section)
Eaves and roof at the ends do not come insulation, how to solve it?
Eaves end is this rafters like in picture. how it's made?
I hope anybody could understand what I thinking.
Best regards,
Jaano
2016-09-05 11:21 PM
Steve wrote:I would like to see the Ctrl + click intersection, I have never made it before, or if you can point me to any GS video that shows this,nojaano wrote:The way you model anything in ArchiCAD depends very much on what you need it for.
Best regards,
Jaano
I almost always model the roof sheathing as a single element rather than as a Complex Profile for Composite.
How to cut out the roof where another roof meets it perpendicular?
Stretch some new nodes from the edge of the roof you want to cut, to about where the intersect is going to be, Select one roof and then use Ctrl-Click on the edge of the other roof to make the roofs intersect in the correct place.
You will find many uses for using roofs and Ctrl-Click to make the intersect.
I use roofs this way as SEO's in my excavation/site terrain models. I model soffits as roofs with 0 slope, sidewalks, garage slabs, etc... lots of things. Ctrl-Click with things modeled as roofs is an important ArchiCAD skill to learn. That is how you make the cutout in the roof I think you are after.
I could post a little video clip if you would find it useful. ?
2016-09-06 12:38 AM
2016-09-06 03:36 AM
2016-09-06 03:21 PM
2016-09-06 04:18 PM
2016-09-14 07:19 PM
