We value your input!
Task bar control : Drawing Manager
Johann_P
Apologies for embarrassing question ..... but I managed to turn on a taskbar that I can't seem to turn off.
What is it called? (So I can change the topic for others to easily search)
And how do I switch it off?
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
Erwin Edel
Looks like you docked the Drawing Manager at the top.
Wiindow > Palettes > Drawing Manager.
There should also be a horizontal line at the top of the palette that allows you to drag it out again so it 'undocks' and shows the cross button to allow you to close.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Erwin Edel
www.leloup.nl
Windows 10 Pro
F8 is default keyboard shortcut (Windows at least).
