2007-08-18 10:35 PM - last edited on 2023-05-26 02:55 PM by Rubia Torres
2010-03-16 09:23 AM
Rod wrote:This is the basic rule for a general project in which you have several kind of composite structures.
For those that intend using this to control your wall intersections
then remember you will also need to create as manydifferent
wall compositesas you have different intersections.
2010-03-16 09:53 AM
alemanda wrote:alemanda, can you explain better what you mean by ...
... and correct me if I'm wrong: if you are so able to get clean intersections in plan forget clean 3D view
2010-03-16 10:02 AM
2012-07-02 09:04 PM
2012-07-02 11:55 PM
2012-07-03 02:35 AM
2017-09-18 06:33 PM
2017-09-18 07:38 PM
2017-09-19 03:45 AM
Siaan5 wrote:Have you turned off the 'Clean Wall & Beam Intersections' button by any chance?
My walls are not intersecting. Even when using the INTERSECT button. Everything is disjointed. I think after using the Graphics Override. How do I go back to default? HELP!
