LeeJaeYoung
Why do two of them appear green? All of them have solid element operations applied.
AC27 on window 11
9 Replies 9
vistasp
The first thought that comes to mind is that it could be a missing classification, or an undefined structural function.
What overrides are you using?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
LeeJaeYoung
If you use hidden selection, it is pierced.
I don't really know what to say.
I don't even know what to show you.
I'm just wondering what to look at when I get that error.
AC27 on window 11
vistasp
What Graphic Override are you using?
= v i s t a s p =
bT Square Peg
LeeJaeYoung
GOC No Overrides
AC27 on window 11
CWagner
Hello @LeeJaeYoung,
the two "slabs" look like morphs. Morph have no blue reference plane, since they are freeform elements and only have a green outline when selected. Slabs however, do have a blue reference plane. While both are construction elements, they have different features, e. g. they use different basic intersection principles.
When selecting the elements, Archicad shows the corresponding icon in the info box as well. If you double click the icon it will show you the selection setting of your construction elements.
Slabs can be be converted to morphs as well. So these morph could have been originally slabs.
More information regarding construction elements, like morphs and slabs, is also available on the Korean Archicad Help.
LeeJaeYoung
I'm not using morphs in my drawings yet.
AC27 on window 11
CWagner
How do they look when all the solid element operations are removed? If the other blue lined openings are still existing, when no solid element operation is used on the elements, it means that these openings where created by using subtract from polygon on the slab.
Slab with solid element operations:
Removing all solids element operations:
Cut out subtract from polygon opening is still existing:
LeeJaeYoung
1.delete
2. Hide selection
AC27 on window 11
LeeJaeYoung
As I study, this phenomenon occurs. Rather, this phenomenon occurs with blue things.
AC27 on window 11
