2006-09-24 06:47 PM - last edited on 2023-05-25 05:58 PM by Rubia Torres
2006-10-09 11:40 PM
vincon2 wrote:vincon2,
...Does Archiforma have the ability to show total perimeter, total SF, user defined fields, etc, etc for scheduling?
2006-10-09 11:50 PM
2006-10-10 01:41 AM
Dan wrote:Thanksvincon2 wrote:vincon2,
ArchiForma will basically create the counters as ArchiForma Objects. You can assign object IDs to them for filtering and also assign various Archiforma parameters for listing. Unfortunately, the Archiforma parameters available for assigning are not as specific as the ones avaiable for slabs. Maybe you could customize the ArchiForma objects by creating special additional parameters to the various ArchiForma object types....I'm not sure about this because I've never tried it.
Bottomline,
I suggested the ArchiForma process becacuse the counter objects are easier to create, modify,bevel, etc....and they know/report what zone they are in.
Don't know if this answers your question but hope it helps,
Dan K
2006-10-10 01:44 AM
Erika wrote:I don't have a problem finding the slabs, I have a problem getting them to appear on my schdeule like I want them to.vincon2 wrote:We know the zones won't pick up the slabs. Making use of the"ID" for each slab allows you to quickly locate them using find and select.
Due to the complexity of my drawings its critical that I don't do things like you suggest because when I make changes, it makes hunting for these areas that need to be corrected a herculian task.
You can increase the ease of finding the slabs by use of specific pens and/or fills.
2006-10-10 05:19 AM
vincon2 wrote:
...I just realized I already own Archiforma and I find it very difficult to use. The dinky manual that comes with it is hard to understand and I am completely lost as to how to use it.
Is there a better training guide out there somewhere?
How did you learn it?
2007-01-25 08:28 PM
2007-01-25 10:48 PM
2007-01-26 07:41 PM
Chazz wrote:You are welcome.
I know I'm coming in late here but I just ran into this myself. Thanks to Laszlo for calling it definitively (and also for your work in the Wiki which has been very helpful lately).
2007-02-01 03:34 PM
Chazz wrote:Absurd workaround: Make the slab accessory 1 Unit think (in my case 1 foot). Then schedule the
there does not appear to be a way to sched the area of the part --a serious drawback.
