2003-11-18 04:44 PM - last edited on 2023-05-26 03:30 PM by Rubia Torres
2003-11-18 05:40 PM
Shae wrote:By the subject of your post, I presume that happens when you are in S/E window. Live or unlinked? Doing exactly what?
I am working on a really big house, and from time to time for reasons I still can't find, it crashes, or more accurately hangs indefinately.
I quit archicad and reopen it and up comes the temporary file prompt, I accept, then the file opens and the whole top storey is missing! 7.0r3 pc.xp.How do you quit?
2003-11-18 06:06 PM
Djordje wrote:Yes it is the S/E window and it is unlinked and it is when
Djordje wrote:I thought of that too but I have a gig of ram and it has no
This sounds like memory problem. How long are you in ArchiCAD on the avergae before hangup/crash happens?
Djordje wrote:I hit the x in the upper right hand corner and then end the application. Is there a way to stop a current process in archicad?
How do you quit?
Djordje wrote:yes I failed to mention I reboot also. sometimes I dont but
I would also reboot; not only restart, reBOOT - shout down and then power up again. Clears all (or most of) the rubbish accumulated.
Djordje wrote:yes, I normally don't but, last time this happened, this morning it gave me no bug report. I will place one next time.
If possible, it would be good if your tech support can take a look at the file and any Bug Reports that you might have created.
2003-11-18 07:19 PM
Shae wrote:Welcome
First thanks DJ for your quick responses to my question in two of the forumns that I have posted questions
Shae wrote:
Yes it is the S/E window and it is unlinked and it is when I regenerate from the model.
Shae wrote:Hmmmm ... Outlook and Real player - known memory hogs. Do one thing: increase the Windows temp file size, preferably on ANOTHER partition, to 2 or 4 gig. That would help, as the S/E generation is disk intensive.
visable reason for crashing. I am running two apps at the
same time. quick books timer and real media player playing
a radio station. Sometimes outlook too.
I hit the x in the upper right hand corner and then end the application. Is there a way to stop a current process in archicad?Backspace, CTRL . (CRTL period)
yes, I normally don't but, last time this happened, this morning it gave me no bug report. I will place one next time.If it does not crash, there will be no bug report. Did you make sure that your layer combo is correct when refreshing the unlinked S/E?
2003-11-18 07:35 PM
Djordje wrote:I will give that a try. I will have to partition my hard drive.
Djordje wrote:Very COOL!!!!! (don't tell me, its' in the manual)
Backspace, CTRL . (CRTL period).
2003-11-18 07:37 PM
Shae wrote:Don't, if you have enough space. Better leave it alone.Djordje wrote:I will give that a try. I will have to partition my hard drive.
