Read more
crashing in section elevation window.
I am working on a really big house, and from time to time for reasons I still can't find, it crashes, or more accurately hangs indefinately. I quit archicad and reopen it and up comes the temporary file prompt, I accept, then the file opens and the whole top storey is missing! 7.0r3 pc.xp.
5 REPLIES 5
Djordje
Ace
By the subject of your post, I presume that happens when you are in S/E window. Live or unlinked? Doing exactly what?
This sounds like memory problem. How long are you in ArchiCAD on the avergae before hangup/crash happens?
How do you quit?
I would also reboot; not only restart, reBOOT - shout down and then power up again. Clears all (or most of) the rubbish accumulated.
If possible, it would be good if your tech support can take a look at the file and any Bug Reports that you might have created.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
First thanks DJ for your quick responses to my question in two of the forumns that I have posted questions
Yes it is the S/E window and it is unlinked and it is when
I regenerate from the model.
I thought of that too but I have a gig of ram and it has no
visable reason for crashing. I am running two apps at the
same time. quick books timer and real media player playing
a radio station. Sometimes outlook too.
Djordje wrote:
How do you quit?
I hit the x in the upper right hand corner and then end the application. Is there a way to stop a current process in archicad?
yes I failed to mention I reboot also. sometimes I dont but
the result is the same.
yes, I normally don't but, last time this happened, this morning it gave me no bug report. I will place one next time.
Djordje
Ace
Welcome
Shae wrote:
Yes it is the S/E window and it is unlinked and it is when I regenerate from the model.
Hmmmm ... Outlook and Real player - known memory hogs. Do one thing: increase the Windows temp file size, preferably on ANOTHER partition, to 2 or 4 gig. That would help, as the S/E generation is disk intensive.
Backspace, CTRL . (CRTL period)
If it does not crash, there will be no bug report. Did you make sure that your layer combo is correct when refreshing the unlinked S/E?
HTH,
Djordje
HP Omen
I will give that a try. I will have to partition my hard drive.
Djordje wrote:
Backspace, CTRL . (CRTL period).
Very COOL!!!!! (don't tell me, its' in the manual)
Yes, I did, it is a very complex model.
Thanks for your help! THis forum works great!!!!!!
Djordje
Ace
Don't, if you have enough space. Better leave it alone.
IF you have a separate partition/drive, and it is free, then OK.
Djordje
HP Omen
