Paopao
multiple offset: how to??
Hi guys, this is the problem: I need to draw my own stairs so I need to be able to use the multiple offset (at 0.3 cm each) to show the stair in plant: how do I do it instead of repeating for each step the offset command? Is there a way to do it automatically?
thanks for your help,
PP
AC26 EDU • WIN 10 • Intel Core i7 2.8 GHz• 32G RAM• NVidia GForce GTX 1080
5 Replies 5
Eduardo Rolon
use command+U which is "Multiply"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
NCornia
A couple other ways: Use the Multiple Offset command in the Control Box (menu Windows>Palettes>Control Box) or use the Drag a Copy/Drag Multiple Copies Method. See image below
I think Eduardo's method may be the best though, just thought I might present some other ways if the situation better fit them.
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Jere
This, plus use the "spread" option would work great for your purpose.
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
I made a videotutorial but it is in spanish...
www.youtube.com/watch?v=b340xXIhaSE
use multiply and spread, set your distance to 3 and drag your cursor in the direction you want to array the object
