Setup & License forum
Forum Posts
About Apache Log4j vulnerability
Dear All, Last week, a critical security vulnerability in Java logging library Log4j has been found. The vulnerability allows attackers to perform remote code execution, which means they can run any code and access all data on the affected machine. I...
Minh Nguyen by Graphisoft Moderator
  • 1369 Views
  • 6 replies
  • 3 likes
Resolved! Strange hotspot stretching in 24
Is it just me or are others seeing this as well? Place the 'Sink Belfast 24' object close to the project origin. View in 3D, select it and try to stretch the front left hotspot. Normally I would drag the cursor close to the hotspot. But now I have to...
Hdmi 2.1 and 4k TV
Hey all, is anyone using a TV with hdmi 2.1 The lG Cx series come with hdmi 2.1 and are gsync compatible. Obviously you need a new compatible GPU with hdmi 2.1 output, which i think is only the new rtx 3000 series. It would be nice to have a sizeable...
Anonymous by Not applicable
  • 378 Views
  • 1 replies
  • 0 likes
install problem
Hello sir I am having problems installing archicad versions 22.23 when I install is blocked at 98% and it is written (installing BIMx desktop viewer) I would like to know why this is what the problem thank you very much
  • 465 Views
  • 4 replies
  • 0 likes
License Reset
Hello, I upgraded Windows and now my license is lost. Is there a way to remotely deactivate a license?? I seem to be stuck without it. If you could point me in the right direction that would be great.
  • 517 Views
  • 4 replies
  • 0 likes
Archicad Start Screen hangs
I've had this problem before. With help form Graphisoft forum members a bypass solution was found quickly. The Archicad Start Screen GUI hangs or Archicad might crash, if one has more than a few recent projects listed there. To avoid this one should ...
Miha_M by Expert
  • 1150 Views
  • 4 replies
  • 0 likes
Problems with Archicad 22
Hello Im an architect from Chile, and im having problems with the software, it doesnt show anything, not even the white screen, nothing. It opens with no problem at all but when i decide to draw or build somethings, does not show the line or element....
  • 234 Views
  • 1 replies
  • 0 likes
Dimensions jumping in plan
Dimensions on plan went crazy when we went to publish the drawing. The numbers appeared onto of each other and the dimensions jumped. Refreshing and restarting the file didn't do anything.
Yvonne by Enthusiast
  • 415 Views
  • 6 replies
  • 0 likes
