Setup & License forum
Forum Posts
Archicad 24 6004 issues after update
I updated to the 6004 update and now have the following issues. Cineware add-on crashes and I can not render. Archicad is extremely slow when opening PLNs. It is taking minutes for the PLN to open after the splash screen appears. This is with a templ...
Too Long by Enthusiast
  • 2184 Views
  • 5 replies
  • 0 likes
Archicad 25: New Survey point tool
Hello, opened up a project in archicad 25 and a few things came up: 1. Original Survey Point object has been removed and replaced with the built in one. The new one had lost original placement and moved far away. 2. Each time i rotate the survey poin...
Anonymous by Not applicable
  • 1776 Views
  • 3 replies
  • 0 likes
AC 25 Mac installation messes up Codemeter
Yesterday I installed AC 25 INT on a Mac 10.15.7 Catalina and Codemeter stopped working for all versions. After an hour or two of checking with the local dealer, reinstalling Codemeter and License Manager, and restarts, things started working again. ...
Ignacio by Advisor
  • 3686 Views
  • 8 replies
  • 0 likes
Resolved! ArchiCAD 10 Translator compatibility
Trying to install ArchiCAD 25 on my laptop. I'm running Mojave so that I can still use the old ArchiCAD 10 translator version (for opening files easier than 10, or which I have a lot--some ooooold jobs come back online). Anyway, I'm getting the repor...
ARCHICAD 25 and Mac High Sierra
Hello, i usually run ArchiCAD on my windows based lap top, however i have a 2011 i-Mac at home which also runs windows via Bootcamp, albeit it not always totally stable. The OS is High Sierra and has successfully run ArchiCAD 24 without any problem i...
Resolved! Archicad blurry (fuzzy/pixelated) lines and text
Hi guys. I built a new PC, and I encountered a fuzzy line issue with my archicad display. First I used a GTX1050 but I switched to a RTX 2070. The 1050 was definitely worse than the 2070, but the issue is still there. I also have a 32" 1920x1080 scre...
Uninstall old AC versions
Am trying to get a bit more disk space. When attempting to uninstall V19, 20 & 21 I get a message that indicates the Java Runtime is not the correct program to uninstall. Dialogue box takes me to a site where I can download the correct version. Do i ...
