Visualization
contour lines not appearing in objects in 3D
adrianasofiasm_
Hi!
Does anyone know why I can't see contour lines for objects in 3D? I already checked MVO and everything is as it should be, I think.
Thanks!
Operating system used: Mac Intel-based 14.2 Sonoma
AC27 USA - MacBook Pro 14" - Apple M1 Pro - 16 GB
3D Styles settings.
I checked, but it still does not show the contour lines
I was having the same problem now and I discovered that it was checked the option "Enable Physically Based Rendering in 3D" from Options/Work Environment/More Options/Experimental Features. Maybe it will help somebody else if you resolved this issue. 🙂
Setup info provided by author
