Unfortunately composites aren't scale sensitive.
Objects (doors and windows) are because they can be scripted that way.
But there are no such options with standard elements.
You do have "Partial Structure Display" options but this will affect the overall width of your composite wall so it is not what you are after.
You can set each skin in the composite to be either 'Core', 'Finish' or 'Other' and then you can use the partial Structure Display option to turn the finish and other skins on or off as desired - but the skins disappear rather than change to another fill type.
Plus another problem is you can not have a 'Finish' or 'Other' skin between two 'Core' skins so your central skin will always show.
Unless anyone else has any suggestions I think your best option is the Renovation filters.
When you save a view of your plan (or elevations/sections, etc.) you can set them to use different scales and different reno filters and of course you can save as many views as you need.
So save a 1:50 view that uses a reno filter with no filter over-rides and also a 1:100 view that uses a reno filter with a fill over-ride.
As this is not something I have to tackle in my daily workflow maybe others have some ideas on how to deal with it?
