I wrote an add-on that does something like that a couple years ago. For text and dimension tools, it looks at the current working window (plan, section, or detail), what the current scale is, and what layers are turned on. I think it did some other things like resetting the defaults for object-based tools to Use object pens, linetypes, & material. I think it also set the dimension defaults to the office's standard and adjusted the witness line gap for the scale it was placed at.
It works well when dealing with a specific standard template for the office, and the users barely notice it's there.
I think the hard part about including that in the Archicad system would be actually setting the whole thing up, every tool, every layer combination/view, etc. I think Archicad would need is not necessarily a one-to-one mapping but the logic to make the decision.
If layerCombination = "Code Plan"
{put text & dimensions on code layer]
I like the idea, but think it would require a really thorough implementation to work for everyone.
Tom Waltz
