2004-03-26 07:35 PM
2004-03-27 12:49 AM
2004-03-29 07:56 PM
Richard wrote:Well ... you knew I was going to say this ... but ot would be even easier if you placed the grab bar in 3D window. It is there then in plan AND elevation.
This would be MUCH more useful if we could place an elevation of an object in the S/E window.
2007-02-23 05:44 PM
2007-02-23 07:01 PM
SPINCODE wrote:It's not something controllable from inside GDL. Archicad's own engine works against us in that case.
I think it must be easy for GS programmers to realise this.
When object is inserted on the S/E window it must
automatical be inserted on "home" floor of this S/E.
When inserting it must use section line surface as a zero level surface.
Possibly it can be not connected to section line at a later time.
PS: it will be much better to get the ability to DRAW some walls (for windows frames), slabs (for different arrangements of facades),
to DRAW some POLYLINE HOLES in the walls and so on.
2007-08-27 10:59 AM
TomWaltz wrote:I am making this "BY HANDS" averytime:
2007-08-27 12:49 PM
SPINCODE wrote:Basil, I agree.
/.......I WANT TO MAKE THIS ALL AT S/E WINDOW WITH AC BUILDING ELEMENTS.
2007-08-29 10:30 PM
Rod wrote:Good old Objective, where is the new version on the new AC11?SPINCODE wrote:Basil, I agree.
Now this may not be the complete answer but if you haven't seen this before
then have a look at modeling with objects in section/elevation window.
2007-08-30 03:46 AM
Joseph wrote:I'm using 11, Joseph.
