Read more
Wishes
Project indexes - change list
Mauhaus
I wonder if there is an easy way to set up extra index fields ind the project index for changes?
I need a list that shows changes and also points to the layout, it belongs to.
Thomas Mau
AC25 INT Denmark
www.mauhaus.dk
iMac Retina 5K 27" 2017 4.2 GHz Intel Core i7 - 40 Gb 2400 MHz DDR4 ram - OSX 10.12.6 - Radeon Pro 580 8192 mb
The world has enough for everyone's need, but not for everyone's greed - Mahatma Gandhi
1 REPLY 1
BlairC_ACA
You can change the "Change Scheme" to add more data fields.
Once you've added fields to the scheme they are able to be access via the index in the way your screenshot indicates.
https://help.graphisoft.com/ac/25/int/_AC25_Help/070_Documentation/070_Documentation-113.htm#XREF_98...
If you get an answer on the 'points to the layout' question I'd be keen to see it.
I would like to be able to generate a historical list showing all changes as the are related to a layout
