Wishes
SHORTCUTS: Multi key sequence
Aurasphere
As in other packages
BUT
to be complete, it needs an alternate escape character eg
Enter should always execute
Mark Wesse
AC26 | Win10 | Since v6.5r
Architerion - Architectural Systems Developer
Aurasphere - Acoustics
Building Biology - Human Compatible Architecture
"--- Every time...do it better ---"
2 REPLIES 2
Lingwisyer
Guru
There is a long post about this somewhere, but as usual, finding things on this forum is a nightmare... If this is a follow up from one of these posts, you should probably link it.
Anyway, implimenting multi character shortcuts WITHOUT an execute button would intruduce a delay which would be sub optimal.
Implimenting it WITH an execute button would increase the the number of button presses required for a lot of the common commands which again is sub optimal. Though I guess I already lose a lot of time to the floating pallet...
I do not remember most of the discussion...
Are you running out of modifier key combinations?
Ling.
Thanks for the reply
Firstly mnemonic is by far the best way to remember ie
'L' for layers
'L' for lock
Enter to execute (or whatever)
I had that hefty FKey 13-24 post which would solve it instantly but I couldnt get the point across despite explaining it for hours
but yeah, more than just nowhere near enough keybinding...well a simple system that can programatically handle it...all the psychology in that other post
I simply want to be able to use Archicad in the satisfying and lightning speed I can for other progs...pref using the keypad but since that looks like not happening, then at least mnemonic driving 🙂
Or this controller...you can use any old midi controller that supports qwerty out. but its limited without gesturing (in other post)
Cheers
Mark Wesse
Learn and get certified!
