Design forum
Is it possible to disable finalize/cancel when using 3d cutaway?
LeeJaeYoung
It's small, but I'm too lazy to click finalize all the time...
AC25 5010 / AC26 4019 on window 11
Yes, after moving the cutting plane you can just hit Enter instead of clicking Finalize. (Just tested it in AC24, should work in other versions too..)
9 REPLIES 9
Mahmoud Qenawi
@LeeJaeYoung, don’t be lazy and click finalize pls pls cuz really you have to otherwise the model won’t be cut.
LeeJaeYoung
What does "pls pls cuz" mean? The translator couldn't translate it... ^^
I understand that your words have no way.
thank you ^^
Pls is short for please and cuz is short for because so I mean please Lee press finalize to get your model cut, thanks to you.
ryejuan
The annoying part is that the finalize button is not consistent in appearing in the same location, end up you still need to look for it. 😆
In the end what is your Objective?
ArchiCAD 9 onwards
david_skogvold
I had the same problem before, it's frustrating to hunt for the tiny button that keeps moving around the screen for every time.
Then by accident I found you can just hit Return / Enter instead of clicking Finalize – made my life a tiny bit easier.
Hi @david_skogvold, you said just hit Return / Enter, that means pressing Enter or what? Sorry need to understand.
Great tip David, I was not aware of this neat little keyboard shortcut.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
thank you so much
Didn't find the answer? Start a new discussion
