2015-05-28 04:53 AM - last edited on 2023-05-26 02:09 PM by Rubia Torres
2015-05-28 05:36 AM
2015-05-28 05:46 AM
2015-05-28 06:28 AM
2015-05-28 05:24 PM
2022-06-15 11:12 AM
Reviving this thread... Is there a way to change the tab type? I am wanting centre tabs after the initial indent.
Ling.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win10 | R5 2600 | 16GB | GTX1660 |
2022-06-15 11:39 AM
After the initial 'custom' tab on any line, it will revert back to 'standard' tabs (what ever spacing that is - 1.25 and a little bit units - text size seems to have no impact on this spacing).
If you look just under the ruler, you will see very small faint marks where the standard tabs are.
Every time you create a custom tab position, the standard tabs before it are wiped out but you will see them after it.
I hope that helps.
2022-06-16 04:03 AM
In the Microsoft and Adobe Suites, as well as AutoCAD:
Header - Hanging - Left - Middle - Decimal - Right
Is this possible in AC? Given how AC is with all other text formatting...
Ling.
2022-06-16 04:15 AM
It seems not.
Just regular left justified tabs only.
No option to change them to other types of tabs.
