Design forum
Wall extension
POLAR BEAR
Hello All,
Beginner question:
Problem 1: In the attached image.  On the roof, the wall should stop at the highlighted perpendicular wall. But it continues few feet till the end of the higher roof. Why?
Problem 2: on the upper floor view, the entire wall is visible while it is trimmed to the flat lower roof. Why is that ?
Thanks a lot!
pb
Screen Shot 2021-11-17 at 17.01.26.pngScreen Shot 2021-11-17 at 17.01.48.pngScreen Shot 2021-11-17 at 17.00.56.png
archicad 24
macbook pro 13"
4 REPLIES 4
Steve Jepson
Did you try not using trim to roof - use Roof for SEO instead ?
ArchiCAD 25 5005 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5 - Maxwell Studio/Render 5.2.1.49- Multilight 2 - Adobe Acrobat Pro
POLAR BEAR
Yes, tries all that, it continues to the higher roof, as if the lower roof wasn't valid.  Revit has a function to work on wall profile, does Archicad have such function?
I thing i'll have to split the wall, lower/ higher portion.
Thanks!
archicad 24
macbook pro 13"
I would say model how it is built, that always keeps these things from happening.
FREE Soffit & Fascia for Rail Tool - https://bit.ly/BIMRithmSoffitandFascia
FREE wall Accessory framing and coverings - bit.ly/BIMRithmWallAccessories
FREE Truss object - https://bit.ly/BIMRithmTrussV1
FREE Custom Tube Object - https://bit.ly/BIMRithmPolyTube
AC 24, Twinmotion current, Windows 11, Msi 10UG with rtx 3070, wacom intuos pro m, Wacom Cintiq Pro 16, razer Tartarus pro.
Archicad does not have this same function as such, but in Archicad 25 it is now possible to create polygonal openings. So if you place a polygonal opening into a Wall, then you can modify the polygonal shape of the Opening to cut the top or bottom portion of the Wall to the exact shape you want.
In earlier versions this could be achieve by Solid Element Operations.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Didn't find the answer? Start a new discussion
Labels
