Ahmed_K
Mentor
Archicad Labels to DWG
When i export a plan to autocad, all labels that uses GDL are not exported correctly , the text alignement is wrong,
Here is the Zone  label , and it's settings
In autocad, it looks like that :
 it's imported  as a Block,
When i open the block , the text anchor points are in the middle , where they should be, and the text alignement parameter is set correctly to " Center" :
i noticed there is some extra "space caracters in the text field , :
When i delete that extra spaces, it looks correct,
Does someone knows this issue and how to fix it ??
Archicad 27
Windows 11 professional
10 Replies 10
Ahmed_K
Mentor
still didn't find a solution, any suggestions please ?
Archicad 27
Guru
Notepad does not interperate it as a simple word space, but a word space and a forward slash...
BALCONY/ / / / / / / / / /
And it is only the last line...
joaopina14
Does AC29 still have this issue? Didn't had time to test it
Ahmed_K
Mentor
i think yes ,
Does anyone have a solution for it ??
Archicad 27
Claudiu Serban
For simple labels like that one, dont use the zone label, use the text/autotext and insert autotext like related zone name and measured net area. It will export as MText with correct appearance.
Archicad 28/29, macOS 26
BenRC
Coming into this late but still appears to be an issue.  All our labels align left when exported to DWG when we want to retain both paper and model space as part of the DWG export.  This occurs to the extent that some labels move outside of the frame where they require one.
Karel Landa
We were dealing with this with one client on our support in Czechia. Were sending it to Graphisoft and it is a known DEF.
Unfortunately it's quite complicated to fix.
Here is a screenshot what works and what does not.
Karel
From Archicad 17
MacBook Pro M1 Max
BenRC
Thanks for sending through.  Basic Text/Autotext labels we can play with some settings and if we're just typing in what is displayed we can get that to work.  ID Labels for doors, windows seem to be default left align.
Guru
Using Autotext in a standard text label seems like a good alternative to the Zone Label. You can retreive all of the same information with it as long as you do not need any formating changes or a divided frame.
