Thursday
- last edited
Friday
Team, I’ve been trying to create new DETAIL MARKERS, but I haven’t found the right way to do it. Does anyone have a tip on how to create detail markers? I’ve attached a picture of what I’m looking for.
Solved! Go to Solution.
21 hours ago
If you are needing a specific look for the marker, you could look at commissioning someone to script you a custom one. Alternatively, you could look around for a 3rd party library which may suit your needs. Someone on this forum who uses a suitable one might stumble into here at some point.
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
Friday
Could you use the Request HomeDB_info to get a usable string that you could measure and scale your bubble from?
Sunday
Lingwisyer, I thought I had responded to your post earlier, but I don’t see it anymore. I’m not sure who to try and see if your tip works. I couldn’t make the marker, so I’m using the default markers instead. It would be great if I could create a custom marker if possible, but it seems like it’s not easy to do.
yesterday
Oh sorry, I had assumed this was under the GDL sub given that it looked like you were trying to create a dynamic width marker, one in which you had utilised Autotext...
I am unsure how you might go about making a custom detail marker from the floor plan...
yesterday
Dear Lingwiayer,
Thank you for the tip and your willingness to help. I appreciate it. I believe this issue requires more than a simple solution. Therefore, I’ve decided to close this ticket as I haven’t been able to find a solution.
21 hours ago
Ling.
4 hours ago
Ligwisyer;
Thank you again for your assistance and help. I am considering this option.
In either case, I am closing this ticket.
Again thank you very much.
