Yvonne
Fills and cut fills not showing in layout
I have had 2 scenarios of this happening where the fills will not show up in the layout even though it is showing in the view.
1. Where it is just a drafting fill
2. The element cut fill (from building material)
Maybe a glitch? I have a section that's been placed on a layout where half of the slabs are showing the concrete cut fill but the other half not.
I have tried relinking, restarting.... etc
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
1 Solution
Yvonne
I figured it out... someone had changed the pen set to the view and I didn't realise.
Go to post
8 Replies 8
Can you show a few screenshots of the issue (settings, section, layout)?
Do you have your model far from Project Origin by any chance?
Yvonne
Yvonne,
Could you still post a few screenshots to illustrate the situation? It would be helpful for others for future reference in case anyone encounters such a situation.
Zdenko
i think i have the same question? but not sure if similar. can't figure out why my bump out concrete line work (6") does not show hatch or pen style as the concrete seen on the left 6" call out.
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
If a part of the geometry is not cut, then it will not have a cut fill and it will be show with the View Pen.
Zdenko
i thought it was related to my location of section cut as shown below but it doesn't matter where i drag the cut line i still get nothing. will look at the settings for view pen as you suggested Laszio, thank you.
Sequoia 15.1.1
Out of the two vertical lines of the Section on your screen, the one on the left is the Section cut line (where the numbers are). The other one is the line specifying the depth of how far the Section would generate the model.
Zdenko
Laszio! thank you!!!! that solved it! i learned something today
 will fix dimension
Sequoia 15.1.1
