2015-07-16
10:21 PM
2023-05-19
03:55 PM
Gordana Radonic
2015-07-17 07:34 AM
2015-07-17 04:35 PM
2015-07-21 02:42 AM
2015-07-21 02:47 AM
2015-07-21 03:25 AM
2015-07-21 03:28 AM
2015-07-21 04:03 AM
2015-07-21 10:13 AM
laszlonagy wrote:Is this new to 19?
Also, you can turn off the Pointer of the Label before placement. Then it works kind of like the Text Tool.
2015-07-21 01:36 PM
Rogerdodge wrote:Well, Labels had Pointers (or Leader, as they called in other software) even in AC18. In AC19 there are new options to specify the Pointer Starting Angle and also lock it, and also there is a new option for the Pointer shape. Plus the Pointer ON/OFF button is new. In AC18 you had the "Use Symbol Arrow" checkbox in the Symbol Label panel of the Label Settings Dialog using which you could turn OFF the Pointer. However, it was available only when using a Symbol Label (GDL Object-based Label). The option to turn off the Pointer was not available when using simple text Labels.laszlonagy wrote:Is this new to 19?
