2015-07-16 10:21 PM - last edited on 2023-05-19 03:55 PM by Gordana Radonic
2015-07-21 01:44 PM
vfrontiers wrote:No problem in this case GS was aware of the previous workflow and was able to do the full transition to the new system. What is weird is why they hid the command so deep, time to add it to my toolbars and add a shortcut to it.
Eduardo,
Well there you go! Looks like I'm back in business... Thanks for the tip.
another Moderator
2015-07-21 04:35 PM
MaxamAC wrote:For this you need to look at the second button in the Geometry Method info box tile. 'Simple' gives one-click placement of the pointer, with the default shape. (This shape is picked up by the eyedropper.) 'Detailed' gives three clicks to define the shape. To place simple labels with custom pointers, you want Independent, Detailed, and the Text label type.
Hating that the text positions just like the previous one without 'asking' where I want to put it, requiring mirroring, dragging, arrow repositioning, etc. to get it back to a rational place.
2015-07-21 04:37 PM
James wrote:That is the extra information that I needed. Thanks
Personally, I can't see using Simple very often.
another Moderator
2015-07-21 09:55 PM
laszlonagy wrote:I had given up trying to use the label tool because I didn't want the arrow or leader line, so this is a welcome new feature in 19!Rogerdodge wrote:Well, Labels had Pointers (or Leader, as they called in other software) even in AC18. In AC19 there are new options to specify the Pointer Starting Angle and also lock it, and also there is a new option for the Pointer shape. Plus the Pointer ON/OFF button is new. In AC18 you had the "Use Symbol Arrow" checkbox in the Symbol Label panel of the Label Settings Dialog using which you could turn OFF the Pointer. However, it was available only when using a Symbol Label (GDL Object-based Label). The option to turn off the Pointer was not available when using simple text Labels.laszlonagy wrote:Is this new to 19?
Also, you can turn off the Pointer of the Label before placement. Then it works kind of like the Text Tool.
In AC19 it is now possible to turn the Pointer ON/OFF with any kind of Label.
2015-07-22 07:02 PM
2015-07-23 12:48 PM
2015-07-23 11:00 PM
2015-07-28 08:42 AM
2015-07-28 02:30 PM
2015-09-01 07:36 PM
laszlonagy wrote:I don't see a place to set this.
The Label Tool has two Geometry Methods: Associative and Independent. You should use the latter.
