Daria_arch
Lines in wall corners in 2d
How can I get rid of the lines in the corners of the walls in the plans? These lines are visible when opening in pdf, and are very noticeable.
Operating system used: Windows 25
2 Replies 2
Guru
Are you printing as PDF or exporting using the inbuilt PDF function from the Publisher?
Daria_arch
I have this no matter how I save the drawing, through a publisher or simply saving the layout as  PDF....
