Missing Model View Options
Red
I am having a recurring issue with my template file. I have every view set and saved the way I need it, but after saving it and reopening to add or change items, each view will state, "Missing (Floor Plans)" in within the View Settings. I open the "View List" under "Project Indexes" and everything is good there so I thought it was just a visual glitch.
However, for example, I noticed that I had views where door or window callouts should be off but they were showing. I open the MVO to check it, and everything is set correctly. The only fix that I can find, so far, is going into View Settings clicking off of Floor Plans, then back on it, refresh the layout view, and it fixes the callout. Close the file, come back in, rinse, repeat, ...
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
44 REPLIES 44
Thanks for the reply and advice! We will implement this solution and let you know how things go.
amesquita
I use AC 26 and i'm dealing with the same problem.
I'm still encountering this issue with Archicad 27 build 5030int.
In the end what is your Objective?
ArchiCAD 9 onwards
@ryejuan
Was your project migrated to Ac27 or started in Ac27?
Also, is it a solo or Teamwork project?
started with AC27 and its a teamwork (BIMcloud Basic) project
ArchiCAD 9 onwards
