Red
Missing Model View Options
I am having a recurring issue with my template file. I have every view set and saved the way I need it, but after saving it and reopening to add or change items, each view will state, "Missing (Floor Plans)" in within the View Settings. I open the "View List" under "Project Indexes" and everything is good there so I thought it was just a visual glitch.
However, for example, I noticed that I had views where door or window callouts should be off but they were showing. I open the MVO to check it, and everything is set correctly. The only fix that I can find, so far, is going into View Settings clicking off of Floor Plans, then back on it, refresh the layout view, and it fixes the callout. Close the file, come back in, rinse, repeat, ...
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
47 Replies 47
ChrisMc_Verdant
Thanks for the reply and advice! We will implement this solution and let you know how things go.
amesquita
I use AC 26 and i'm dealing with the same problem.
ryejuan
I'm still encountering this issue with Archicad 27 build 5030int.
WINDOWS 11 PRO
@ryejuan
Was your project migrated to Ac27 or started in Ac27?
Also, is it a solo or Teamwork project?
ryejuan
started with AC27 and its a teamwork (BIMcloud Basic) project
WINDOWS 11 PRO
I am having a very similar issue with BIMcloud, I would like to revive this thread.
Specifically, in files we work in on Teamwork (BIMcloud), the view settings will seemingly randomly change the MVO. We had issues with MVOs going missing in previous versions, and it was a known glitch, but it seems that now the problem is the MVO will just change on its own. One day I will publish drawings and they will look correct, and the next time I go to publish things will randomly change.
One note, we work off of a template that was originally developed in AC22 (or previously possibly), is it possible that the glitch is built into our template? Otherwise we are currently working in AC28, we keep up on the latest builds.
AC 28amp;
2021 MacBook Pro 16" 32GB Apple M1 Max
MacOS Sonoma 14.6
Ancha
Same issue 8/8/2025 Archicad 28.2.1 (5101) INT FULL - using Bimcloud SaaS.
Does not make any sense.
ryejuan
We are also still encountering this but the funny part is that I am the only one working in the project (just uploaded the file in BIMcloud since we are paying for it) then still am encountering this issue need to recheck all MVO if one of them is "missing" quite disturbing especially when you are publishing out docs that you know are in order way back then you will find out from your colleague or boss that why your drawing is wrong??? (embarrassing moment...) Hopefully they can resolve this issue by a hotfix or something since they got their funds to do their back end troubleshooting... 😉
WINDOWS 11 PRO
