2021-01-29
10:53 PM
- last edited on
2023-05-23
12:09 AM
by
Gordana Radonic
Solved! Go to Solution.
2023-12-05 03:30 PM
Thanks for the reply and advice! We will implement this solution and let you know how things go.
2024-03-07 06:23 PM
I use AC 26 and i'm dealing with the same problem.
2024-06-14 05:02 AM
I'm still encountering this issue with Archicad 27 build 5030int.
2024-06-19 12:29 PM
Was your project migrated to Ac27 or started in Ac27?
Also, is it a solo or Teamwork project?
2024-06-24 12:14 PM
started with AC27 and its a teamwork (BIMcloud Basic) project
2025-04-10 06:52 PM
I am having a very similar issue with BIMcloud, I would like to revive this thread.
Specifically, in files we work in on Teamwork (BIMcloud), the view settings will seemingly randomly change the MVO. We had issues with MVOs going missing in previous versions, and it was a known glitch, but it seems that now the problem is the MVO will just change on its own. One day I will publish drawings and they will look correct, and the next time I go to publish things will randomly change.
One note, we work off of a template that was originally developed in AC22 (or previously possibly), is it possible that the glitch is built into our template? Otherwise we are currently working in AC28, we keep up on the latest builds.
